kelly76
Message 1 of 3
bt tv order
i ordered bt tv last night and i skipped past ordering the mini adapters to package and i need them and i dont no how to cancel order to re add them
2 REPLIES 2
DanielS
Moderator
Moderator
Message 2 of 3
Re: bt tv order
Hi @kelly76
It may be best if you contacted us directly so we can keep your BT TV order open and look into sending the mini adapters separate. I'll send you a private message with some info that I need.
DanielS
DavidM
Moderator
Moderator
Message 3 of 3
Re: bt tv order
Hi Kelly,
Thanks for sending over the details. I'm sorry for any confusion with the order. I've placed an order for the mini adaptors for you. They should be with your in the next couple of days. I hope that's ok for you.
Cheers
David
