During my last upgrade, I accepted the offer of Amazon Prime Video free for six months. I now wish to cancel this but cannot see how to do so. Can anyone help?
Hi heenebeach
Just managed it. Went to My TV products under My BT. Tracked right until I found the Amazon Prime product which had a "Renew" marker against it. Went through that "Renew" process and as well as renewing option it gives you a cancel option. A bit long winded but quicker than hanging on the phone. Good luck!
Many thanks for that. I'll keep my fingers crossed and give it a try!!
My search only took me to my original order and removing the Prime video meant I was re-ordering My tv again. I couldn' t find what you described. Can you offer any more help?
Hi - Have a look at these screen shots and see if they help. When I log onto BT and got to the My BT Homepage I get this view.
When I “click” “Your products” - “Manage” I get:
I then “clicked” on “TV and sport” - “Manage” and I get a list of options.
I “click” on the “>” to get to the end where it gives me the “Amazon Prime Video” option.
When I “clicked” on “Renew” it took me to the “Order Amazon Prime” which also gave me the option to “Cancel” it. I don’t want to try it again to get more screen shots just in case I end up getting Prime again.
Good luck
Many thanks CapabilityKev.
I don't have TV & Sport but do have TV. When I click on TV I then get Your BT TV image and Amazon Prime video - trial with a box showing 'Manage' but no forward arrow. When I click on 'manage' I get taken to a page headed 'Progress your order'. If I follow this through, I am amending my (completed) order. I quickly escaped from that.
It's really frustrating.
I think you should try that. I was similarly worried about that but pushed through and got a "cancel Prime" option. If it doesn't, I am fairly sure it gives you the option to "cancel order" option before you finally submit.
Thanks again.
I did try that a few days ago but having taken it so far, I was rather wary that I might be cancelling the order. I'll try again.
