Message 1 of 3
cannot create new BT ID technical site issue
recently joined bt when i get to the final stage of creating id it just says technical issue please try later? Its been like tis for days now?
2 REPLIES 2
Message 2 of 3
Re: cannot create new BT ID technical site issue
Hi @TheBritSoldier  Thanks for getting in touch with us here in the BT Community.
I'm sorry to hear that you're having trouble creating a BT ID, We have a dedicated page on how to create a BT ID here
Have you had a BT ID in the past?
I'd recommend using a different email address to see if that solves the issue.
Chris S
Message 3 of 3
I know this was probably sorted ages ago, but in case anyone else finds this thread with the same issue, I wanted to share what worked for me.
I had exactly the same problem with the “We seem to have a technical issue. Please try again later” message when trying to create a BT ID. After a lot of back and forth, I was told it was down to the email address I was using.
I was registering with a Hotmail email, which BT’s system wouldn’t accept properly (even though it doesn’t tell you that). As soon as I switched to a Gmail address, the registration went through without any issues.
So if anyone is stuck in the same loop:
• Try registering with a different email provider (Gmail worked for me)
• Once the BT ID is created, everything else works as normal
Hope this helps someone who ends up here as frustrated as I was 🙂
