polish
Message 1 of 4
changing contract
Sorry not sure where to put this question?
How and where can you find the end date of your current package? also do BT send deals near to the end of the contract? I am sure they did the last time?
Should you wait until the current package is almost ended and then look on line for another deal?
Many thanks
3 REPLIES 3
Message 2 of 4
Re: changing contract
Try
https://www.bt.com/appsordermgmt/secure/listoforders.do
You may get a call from near the end, but its best to call them on 0800 800 030.
Message 3 of 4
You can use this link to check contract length
https://www.bt.com/appsauth/genericlogin.do
I would not bet on getting any deals sent out to you. You would be better contating the Options Team 0800.800.030 and try to negotiate a deal.
polish
Message 4 of 4
thank you
