colineve
Message 1 of 3
check data usage
Can anyone tell me if it is possible to check ones own usage even though you are on unlimited option. When I ask online it just says you are on unlimited and not to worry but I need to know to check other things
2 REPLIES 2
Message 2 of 3
Re: check data usage
Distinguished Guru
Distinguished Guru
Message 3 of 3
This shorter thread gives a workaround.
