ljc67
Newbie
Message 1 of 2
email v id PLEASE HELP ME UNDERSTAND
HI
I am sure this is simple but its confused me!
I have a BT ID eg  XXXXNNNNXXX@BTINTERNET .COM
and a userid/bt id I also login into  eg  xxxx@gmail.com
I am confused when I use which
- login to website seemed to nr the gmail one
- login into bt sport seemed tp btinternet one
- loging to watch live gmail one
anyone explain or make sense of my confusion
Tags (1)
1 REPLY 1
Message 2 of 2
Re: email v id PLEASE HELP ME UNDERSTAND
Your email is xxxxxxx@btinternet.com and you will have a password for that. Other than the password this can not be changed.
If you have set up your BT ID as xxxxxx@gmail.com This is what you must have selected it to be when you set it up. If you log onto MyBT and go to your profile, you can change the username and password to what ever you want it to be. It does not need to be the same as your email address and password unless you want it to be.
Hope this helps.
