lukejannas
Newbie
Message 1 of 5
faulty telegraph pole
Hi
I had intermitted broadband service for 3 years numerous complaints to BT and eventually the engineers discovered that it was the pole which moved during strong winds. The pole had a no climb notice on it. I have written to the customer service man ager for compensation as yet no offer of compensation, should I go to the ombudsman.
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: faulty telegraph pole
Is the pole accessible by using a hoist (cherry picker)?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 5
You have to exhaust the BT complaints procedure and you need to get a deadlock letter from BT which should outline why they are not giving you compensation before you can go to the Ombudsman.
See link for procedure that you must take.
https://www.ombudsman-services.org/sectors/communications
Message 4 of 5
Moderator
Moderator
Message 5 of 5
@lukejannas welcome to the community and thanks for posting, I'm really sorry this has been ongoing for such a long time. Has the fault been repaired?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
