GrizzlyKt
Newbie
Message 1 of 3
help removing old accounts
hi could someone please help remove some old bt id accounts i have 4 but 3 are old and i cant update my cloud details thank you for any help
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: help removing old accounts
Hi @GrizzlyKt Welcome to the forum and thanks for posting.
If you have old accounts linked to your BTID the BTID Chat Desk will be able to remove these for you.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
GrizzlyKt
Newbie
Message 3 of 3
HI THANK YOU FOR YOUR HELP ALL SORTED
