lairdy1963
Message 1 of 6
open order on account
Hi, I have an open order on my account that has been there since June. Can this order be closed as it is affecting my ability to order other services.
5 REPLIES 5
DavidM
Moderator
Moderator
Message 2 of 6
Re: open order on account
Hi @lairdy1963,
Welcome and thanks for posting. The orders guys should be able to close that off for you. You can contact them on 0800 800 150. Can you try that and let me know how you get on?
(edited by mod) 👍
Cheers
David
CJT80
Recognised Expert
Message 3 of 6
@lairdy1963
That number should be 0800 800 150.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
DavidM
Moderator
Moderator
Message 4 of 6
My mistake @CJT80. Thanks for pointing that out.
Cheers
David
CJT80
Recognised Expert
Message 5 of 6
@DavidM
No problems, we can all make a simple mistake, was worried the OP may call by accident 😀
Kind Regards
CJT80
lairdy1963
Message 6 of 6
Hi. Thanks for your help. The open order will be closed in the next 24 hrs. Cheers.
