Message 1 of 4
A problem with registering for BT Wifi
Hello, i've been with BT for quite a while now, for about 2/3 years i think. I have package number 3 (which include unlimited wifi) i only recently became aware of using wifi when i'm out and about, so i tried to sign up for BT Wifi. Whenever i put in my master user name and password, a message pops up in red saying that my account is not active?! I don't have trouble accessing any other area of my BT and would very much like to register for the Wifi i'm entitled to. Please help!!! 😞
3 REPLIES 3
Message 2 of 4
Re: A problem with registering for BT Wifi
Are you using your primary e-mail address and password, the one that BT first gave you when you joined?
it should be xxxxx@btinternet.com.
Check your status here https://www.bt.com/wifi/secure/status.do
Message 3 of 4
I am yes. I just checked my status and it said the same thing "This account is inactive" so i went to "forgot password" to try and see if i could be sent a new password and reset it. But it said my account has been suspended now?!!! This is insane, i've had no emails, i haven't has any change in billing or using BT at all. I don't understand what is going on?! 😞
Moderator
Moderator
Message 4 of 4
Hi LuxLivingDead,
I'll be able to look into this for you. Please send me in your details using the "Contact Us" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
