Louby
Message 1 of 2
Access control problems
I put my son's two android devices on blocked access between 9.30 pm and 6 am. However the router blocks other devices too which rather defeats the object a little. It is random in its blocking, sometimes it does sometimes it doesn't. We then have to put these other devices on to bt fon to get internet access. Can anyone tell me how to get it to work correctly and only block the devices I have requested it to?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Access control problems
Hi @Louby and welcome to the forum.
Take a look at BT Parental Controls on your devices and let us know if that helps.
Cheers
David
