- Mark as New
- Bookmark
- Subscribe
- Subscribe to this message's RSS Feed
- Highlight this Message
Does Norton work with the Android One Core 3.1. or should I get an Android 10 or 11 phone as I am looking to change?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
Re: Android One UI Core 3.1. and new Norton antivirus
- Mark as New
- Bookmark
- Subscribe
I'm a bit of a technophobe, so don't know if the Samsung A12 with the "One UI Core 3.1. operating system is Android 8 or later. I don't want to buy a new phone with the wrong operating system and then find that it won't work with Norton as I will be back where I already am with Android 6 on My Samsung S5 neo.
- Mark as New
- Bookmark
- Subscribe
It seems that Android One UI Core 3.1 is a "skin" for Android 9, so it should work with Norton as Norton works with Android 8 and above. Doesn't it???
- Mark as New
- Bookmark
- Subscribe
Hi @brewup51, if it is Android 9 then that will work ok with Norton.
Best double check your device first, and you can find out your current Android operating system version:
• From the Home screen, tap the Settings icon to go to the settings.
• Tap About Phone or About Device.
• Under Android Version, you can find the version of Android that runs on your device.
Cheers
John
- Mark as New
- Bookmark
- Subscribe
- Mark as New
- Bookmark
- Subscribe
if you are purchasing a new A12 then that should come with android 11 and is scheduled to get android 12 in next few months. android 12 is most up to date firmware
- Mark as New
- Bookmark
- Subscribe
That's brilliant. Thanks for all your help. Much appreciated. M
