cartoony
Message 1 of 2
Android, how to backup a folder on the SD card
This page says that I can simply click on + and add a folder to the backup
https://www.bt.com/help/broadband/bt-cloud/getting-set-up/use-bt-cloud-to-back-up-content-and-device...
However there is no + symbol and going in to settings I can only backup pre-specified folders, I do not get the option to add my own folder too the backup
How do I backup a folder on the SD card please?
1 REPLY 1
liamh
Message 2 of 2
Re: Android, how to backup a folder on the SD card
I'm also struggling with this, it looks like it will only back up photos in the default location, with no option to add other folders or SD cards.
