Message 1 of 3
Anti virus software
I'm unable to download the Norton virus protection onto my Hudl2 and assume that the software isn't compatible given the tablet is a few years old. Correct? If so, any suggestions about a suitable alternative software?
2 REPLIES 2
Message 2 of 3
Re: Anti virus software
BT Virus Protect must have Android 8.0 or above.
See link
Important updates to your virus and password prote... - BT Community
There are many free AV apps on the Google Play store. Check out the reviews and decide which app suits your needs.
Message 3 of 3
Hi
Thanks for the clarification. Much appreciated!
