Message 1 of 3
Antivirus
I'm humming and harring abbout not renewing my av and using the free one with my bt but I can't find anything online (bt site)  that actually tells me what it is bar 'mcafee'.
Is is just a BT branded McAfee Internet Security 22.1 ?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Antivirus
It's McAfee and that's all you need to decide to go for something else (that's a paraphrase of what the founder, John McAfee, has said let alone others here). If you're happy with what you've got the best advice is to stick with it.
Message 3 of 3
Re: Antivirus
It is just a rebadged McAfee product although I am not sure which one.
My advice and that of others on the forum would be not to install BTVirus Protect/McAfee. It can cause problems on some computers and is a resource hog. Do a search of the forum to see the problems.
There are far better free antivirus programs available such as Avast Free and AVG Free. If you are a Windows 10 user, the Microsoft antivirus which comes with that is getting good reviews and is free.
