capitol1952
Message 31 of 53
Re: Anyone 500GB cloud upgrade yet?
Problem solved, now showing 100GB on both website and app. Thanks to the mods for your help and I hope you other guys get it sorted soon.
dastro490
Message 32 of 53
The problem is solved for me too. Now showing as 500Gb limit on the website and the app.
Thanks to the Mods for their help.
Ian.
AlanClutt
Message 33 of 53
Just checked mine aswell, showing as 500GB online and app.
Alan.
Moderator
Moderator
Message 34 of 53
Great result guys.
Thanks all for letting us know it's sorted Smiley Very Happy
Cheers
David
cmwb
Message 35 of 53
Re: BT Cloud 500GB ?
Hi,
My storage is still at 5Gb and should have gone upto 100Gb, help please mods ?
Regards
Colin
Moderator
Moderator
Message 36 of 53
Hi @cmwb,
Thanks for posting. Can you please send over your details and I'll check this for you? You'll get the contact the moderators link in my profile.
Cheers
David
cdturri
Message 37 of 53
Hi,
Mine is still not upgraded. I have send DavidM a private message.
Thanks!
tenbyboy
Message 38 of 53
Just to confirm mine is now sorted to - thanks for the help guys 🙂
Moderator
Moderator
Message 39 of 53
Hi @cdturri sorry your Cloud storage has not updated yet.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
cdturri
Message 40 of 53
Hi John, I have sent the details already (yesterday) but the issue is still not fixed. Any ideas?
