JimD
Message 1 of 3
BT Cloud All my files.
 Is it possible to reset the names of the devices under All my files?   I have a desk top and laptop that have the same name--and not one that I chose.  Grateful for any help--can't seem to find it mentioned in the Help system.
2 REPLIES 2
BT Cloud Expert
BT Cloud Expert
Message 2 of 3
Re: BT Cloud All my files.
Hi Jim,
It's not currently possible - computer backups use a common naming convention, which is: [First Name of User Account]'s [Mac / Windows] Computer.
So If my user account was Joe Blogg's on my Windows laptop, that machine would appear as 'Joe's Windows Computer'.
Thanks,
Joe
BT Cloud ExpertJoeV
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Cloud. I am here volunteering my own time to give advice, on BT Cloud queries. Go here for more info.
JimD
Message 3 of 3
Thanks (again) JoeV...I thought I remembered it being possible to change the, but probably before the changes last year.
