Message 11 of 21
Re: BT Cloud Downloads Stopping At 1Gb.
Hi
I have also just experienced the same problem, was trying to download some drone footage off the cloud onto my phone, tired the cloud app, android edge browser and a download manager and all of them stopped at just over 1gb, this is ridiculous!
Pete
Message 12 of 21
Thanks for the report Pete. It would be appreciated if you could try to report it to BT. Regards Bob.
Message 13 of 21
No problem, but can I do it online? As I don't want to sit in a phone queue for ages 😉
Pete
Message 14 of 21
No sorry Pete. You need to phone as it's very specalized BT Cloud dept. cheers Bob.
Message 15 of 21
Oh, I have used the email address from the app and reported the problem so hopefully this will be enough?
Pete
Message 16 of 21
'so hopefully this will be enough?'
No, your report will be memory holed and they will not attempt to contact you.
Message 17 of 21
Hi, well I'm afraid you were wrong, I had a phonecall from Ben at the cloud team who rang to say he'd read my email and was looking at the problem with the developers and he asked me to share a 2gb video file so they could use it to carry out tests on, I'll keep you all updated if I hear anything back.
Pete
Message 18 of 21
Well done Peter. Let's hope Ben can sort it for us. Regards Bob.
BT TV Expert
Message 19 of 21
Morning,
Sorry for the delay getting this one fixed, if you try now you should be able to download files over 1GB successfully.
Message 20 of 21
Thanks, I tried it a couple of days ago and seemed to work fine, thanks again for fixing it, it was worth the wait.
Pete
