badhamsj
Message 11 of 651
Re: BT Cloud Upgrade(?), what have you done?
I applied the upgrade on Windows when it popped up this morning. It looks as though everything added since June has had to be uploaded again.
When the software was installing it looked like a new software provider was involved.
Maybe BT have moved the backend to a new provider and haven't finished moving the data across yet. If this is the case I would have expected some sort of migration notice.
dhogarth
Message 12 of 651
BT - how can you do an "upgrade" like this without providing some user information/help about what is going on? I have no idea how I can manage my content at the moment. I received notifications that Smart Folders were being created but I don't know where they are or how to look at them (or even why they were created). I got through to BT Help after a very long wait, and spoke to someone thousands of miles away who didn't have a clue - all she could tell me was that the upgrade has been done this morning, maybe things were still building and maybe it would be better in 24-48 hours, if not then call again.
BT - do you read these forums? If so, please publish some up-to-date help and notify your users!
doleawg
Message 13 of 651
@ dhogarth
Genius isn't it.....
Moderator
Moderator
Message 14 of 651
Hi guys,
Thanks all fopr posting. Can you take a look at BT Cloud Update. If you're still having problems drop me over an email with the details and we'll try to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
westonmaid
Newbie
Message 15 of 651
saves me a phone call so thanks for that
doleawg
Message 16 of 651
@DavidM
Why not warn in advance? Here is a question. In my orignal settings I had specified 2 folders (whcih have subfolders) that I wanted to sync as back up. These folders are in the cloud but they don't appear in the set up dashboard?
Moderator
Moderator
Message 17 of 651
Thanks for posting @doleawg.
I'll pass the questions back to the could guys and will post back when I get a reply.
Cheers
David
Kudos”Kudos”
doleawg
Message 18 of 651
@DavidM Can you also tell them that when I upgraded the app on my iPhone it resynced what was already sync'd. Do these guys test software before releasing?
peter7769
Message 19 of 651
Can someone tell me what's happening with the Android app, the old one tells me to update but there is nothing in the Google play store!
Pete
doleawg
Message 20 of 651
@DavidM
Some visuals of the issue. I had specified 2 folders to back up 'documents' and 'Family Photos and Videos'
This visual shows they are in 'your' cloud
http://imgur.com/x1l8rRo
However this visual shows that in the setings they are now lost as defined back up folders
http://imgur.com/sXRNG0h
and this visual shows that when I try add the 'Family Photos and Videos' folder it won't let me, I have to individually add the 3 sub folders whcih means resyncing 45Gb of files.
http://imgur.com/afE19mE
Genius......
