TomP63
Message 411 of 1,226
Re: BT Cloud Won't Start
Is there any further news on the BT Cloud update promised for delivery this week?
Jules68
Expert
Message 412 of 1,226
Part of it, the update to server software, has apparently been delivered and certainly some users have noticed improvements. The client software (desktop) hasn't been updated yet.
TomP63
Message 413 of 1,226
Thanks! I tried a complete reinstall a couple of hours ago on my laptop and the process still hangs, just as before. Hopefully, the client software isn't too far away.
New_To_UK
Message 414 of 1,226
Hey, do you get as far as being able to clicking the icon from the system tray and opening the popup?
TomP63
Message 415 of 1,226
Unfortunately, no. The screen opens the BT logo and says Installing..... It then asks for various settings and preferences. After that, nothing!
Nothing has appeared so far in the system tray.
Travelusa
Expert
Message 416 of 1,226
Mine so far seems to be working
After clearing out all the old software Plus the hidden one.
Reinstalled ...make sure after installing it is using the default folder or it will start another one.
Select the folders you want backed up also change from continuious to daily.
The Icon you were on about is working clik on it and it give the files it has backed up .
As i said appears to be working now no issues with the harddrive at 100 % cpu back to normal
No lockups ....
New_To_UK
Message 417 of 1,226
sounds like it is installed? These are the steps I saw from a new install and from what you describe - you should be on Step 8
  1. BT Cloud Installing Message
  2. Then login window - Enter Username and Password
  3. License Agreement - Click Accept
  4. Preferences Window -  starts with Add a Folder popup 1 of 7 - (Click Skip)
  5. Choose backup folders
  6. Click sync tab - skip the messages - and browse to old sync folder and enable sync if you want it (New installation suggests a new sync folder)
  7. Click Save - window disappears
  8. Check in system tray and click on cloud icon which opens a white popup
Try double clicking on the desktop shortcut to see if it launches it in the system tray? The system tray is inside the up arrow on the bottom right.
TomP63
Message 418 of 1,226
Yes, it has appeared in the system tray and does appear to be syncing! However, it does not launch on the desktop at start-up and there is no desktop dashboard available yet.
Travelusa
Expert
Message 419 of 1,226
Click on icon then go to settings I found both startup and keep logged in unticked
Tick them and save
AJW1100
Message 420 of 1,226
I don't want to fetch every thing!
Is this what you normally get when you open the Web App? I am sure I used to get a normal sort of folder view straight off and could select the folder I needed.
This is a PITA having to download this every time, takes forever......
Also found that in Windows Media Player it has corrupted a lot of my file (Music) titles, The title and what is played are now different, It will take me days to check and rename 1000's of tracks.
The questions only easy if you already know the answer
