Ted_ntsx
Message 1 of 30
BT Cloud broken
Anyone else having problems with BT Cloud?
BT cloud no longer works for me. The PC app just sits there doing nothing, apart from an occasional flash of "syncing".
The Web inferface just reports "Error Session expired. Click OK to try again" in a broken up message,  and nothing is "clickable".
29 REPLIES 29
LindaR1
Message 2 of 30
Re: BT Cloud broken
I have the same problem. Any word on how to fix it please?
Dickie_Flosp
Message 3 of 30
Re: BT Cloud broken
Broken for me too. When I log into the web site, I just get a dimmed screen with a "Session Expired" message on top of another error which is unreadable because it's hidden by the "Session Expired" message. Nothing is clickable because the whole screen is dimmed.
Been like this for a couple of days now.
bingefeller
Message 4 of 30
Re: BT Cloud broken
Same problem for me.   😞
Ted_ntsx
Message 5 of 30
Re: BT Cloud broken
Ok,  at least I know its not just me.
I suppose BT will say nothing as usuall...
bingefeller
Message 6 of 30
Re: BT Cloud broken
What browser and operating system are you all using?
I have tried Chrome and Safari on Mac Catalina.  Everything is up to date 100%.  I have disabled all plugins and still can't get in.
I know someone will probably say install the app, but I want to organise my files from the web interface because I don't want the client downloading all my files onto my computer every time I open it.
DavidM
Moderator
Moderator
Message 7 of 30
Re: BT Cloud broken
Hi guys,
Sorry you're having problems with the Cloud. Have you tried contacting the helpdesk?
You can get them on 0800 500 3114 and they will be able to help you.
They are open 9am to 9pm Mon - Fri and 9am to 6.30pm Sat and Sun.
Cheers
David
android3
Message 8 of 30
Re: BT Cloud broken
Had the same problem for about three days cant access cloud on any device from browser or apps.
At the moment cant even find a way to contact bt keep getting sent to this forum.
Anonymous
Not applicable
Message 9 of 30
Re: BT Cloud broken
The Session Expired message suggest that, maybe, you shut your browser down without first signing out, try clearing cookies and history for the btcloud website and try again.
welshgit
Message 10 of 30
Re: BT Cloud broken
i read this thread and thought i'd log in to see ,mine works ok . mind you i think the site is not that good anyway
