Message 1 of 3
BT Cloud forced update
Just had the newest update forced on me and suprise suprise the entire program is not completely useless again. Doesn't sync anything in my folders the same as the last version didn't.
Thanks once again BT for making BT Cloud completely useless!!! Honestly if the storage wasn't free then I wouldn't even attempt to use it.
Absoutle joke!
2 REPLIES 2
Distinguished Expert
Message 2 of 3
Re: BT Cloud forced update
The latest version is 17.3.0.45, and as you say, you can't open BT Cloud until you have updated.
There are no problems here, but if you have a large number of files, then you may have to wait for a few mins.
The web portal shows all my files....no problems.
You can always call BT Cloud helpdesk.
Message 3 of 3
There are problems it once again does not work as it should as it is not automatically backing up the files.
Calling the helpdesk is about as helpful as asking my 1week year old what I should do the software is broken and there is nothing that someone reading from a script is going to be able to fix on the phone to me!
