Newbie
Message 1 of 2
BT Cloud: is one way sync an option?
Hi there. Is it possible to have one way sync setup on BT Cloud? I'd like everything I copy into the local BT Cloud folder to sync to the cloud, but I don't want to keep the local copy on my PC's HDD.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Cloud: is one way sync an option?
Hi @stevanjudd,
I'm sorry you haven't had an answer to your post. If you contact the Cloud Helpdesk on 0800 500 3114, they might be able to answer this for you.
PaddyB
