simplysup
Message 1 of 5
BT Cloud keeps shutting down
I posted this message a couple of days ago, only to discover this evening that JohnC2 had seen fit to move it to a general topic concerning BT Cloud, and bury it in the (still climbing) 36 pages of that topic - not appreciated.
This is a separate issue from the more general problems reported in that thread. When it is running, BT Cloud works OK, syncing my files. My issue - which I've only seen one other customer report, in a response to my original post - is that the BT Cloud app keeps closing itself, and I have to manually restart it.
To (re)summarise:
The BT Cloud app keeps shutting itself down - or something else on my system is shutting it down, although if so I've been unable to identify the culprit.
When I start the app, it starts minimized in the system tray, and starts syncing. However when I check it a little while - time varies - later, the system tray icon disappears, and I have to manually restart the app.
In settings, the app is set to "Open at Login", "Keep me logged in", and "Show system notifications".
Any ideas on how I might troubleshoot this issue?
Nigel
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: BT Cloud keeps shutting down
Hi @simplysup and thanks for posting.
I think we'll need to take a closer look at this for you so can you drop me over an email with as much detail as possible and we'll take it from there. If possible can include a few screen shots of what you're seeing?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
mark553421
Message 3 of 5
Same for me. I have been trying to backup my files for four days now. While the app is running, it consumes 30% of my CPU. When I leave the machine, the app closes itself after a short while.
All that cloud storage, and an unusable app!
It was fine before the 'improved version'.
Mark
simplysup
Message 4 of 5
As of the latest update (15.2.8.24 is what my settings screen shows) which was offered yesterday, the BT Cloud app has been running OK, without shutting itself down, for close to 24hrs. I am hopeful this is a permanent fix.
Nigel
Fellwalker
Message 5 of 5
Did anyone ever sort this out?
I have just realised that my BT Cloud app has been doing the same.  It does open automatically on Windows Start.  Today it asked for my password again!  If I open it manually it has A LOT to catch up on, and starts to backup using 36% or more, but closes after about a minute.
I've updated the app to 17.3.0.38 (prompted from within the app) and it is still shutting itself down.
To err is human, but to really mess it up requires a computer
