Adyc
Message 1 of 6
BT Cloud login problems
I recieved a text saying I need to update my cloud software, tried to login, even reset my password so I know it is correct. Looking on here it seems it is a known problem, can anyone help please?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT Cloud login problems
Hi Adyc,
Did you manage to get logged into bt.com to do this yet?  If you need any assistance send me in your details and I'll be happy to help. You can find the contact the mods link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Adyc
Message 3 of 6
Hi Neil O, you just tried to ring, I am free now if you could ring back, thanks.
Adyc
Message 4 of 6
Hi,
I was away for the weekend and could not use my temporary log in, could you resend please and I will try again.
Moderator
Moderator
Message 5 of 6
Hi Adyc,
That's been resent for you now. Let me know if it works.
Neil
Kudos”Kudos”
Adyc
Message 6 of 6
Tried again but still no success.
