RichardK
Message 1 of 6
BT Cloud not deleting folders in Deleted Items
I’m unable to delete 6 folders in my Deleted Items Folder.  If I click on Empty Deleted Items’ it fails and comes back with “We encountered some errors when purging deleted items.” If I select any of the 6 folders individually and then click ‘Delete Forever’ it still doesn’t work, but comes back with ‘A error occurred when deleting the folder(s).’  I have been able to delete other files in the Deleted Items folder.
When I go to ‘All My Files’ it says I’m actually only using 156GB of my 1000GB, but it’s also saying I’ve now exceeded this amount, so I need to delete these unwanted items to free up space! (Not sure how it crept up to this limit as the stuff in Deleted Items should only be of a similar size, but that's probably other problem...)
Anyone else have this problem or any suggestions on how to fix it please?
5 REPLIES 5
jam2000
Expert
Message 2 of 6
Re: BT Cloud not deleting folders in Deleted Items
I'm having the same issue, did you manage to resolve this?
RichardK
Message 3 of 6
Nope, not yet - and had no response/help from BT.  I was hoping the recent software updates would have fixed things, but the problem still remains 😞
RichardK
Message 4 of 6
Just had a further play and seen that the folder sizes are now shown - and that the offending folders were only about 1.1Gb anyway.  So I delved into this forum a bit more and saw that it does full versioning of files.  As I had four .pst files being backed up (totalling >8Gb overall), this meant that I had over 100 versions of each of these - hence my allocation being eaten up.
So I think what I now need to know is that has anyone found a way of limited the number of versions of backups that are kept to a sensible figure?
JoeeeeeeR
Message 5 of 6
Hi @RichardK,
I don't think there's a way of limiting file versioning (this should be something BT introduce as a top priority!!), but I would recommend against backing up .pst files at all - they tend to mess up most backup solutions in my experiance.
If you haven't already, my advice would be to move the .pst files to a folder that BT Cloud isn't set up to backup automatically.
ellanvannin
Message 6 of 6
I have the same problem. I've just had an update but still no luck. BT should be monitoring the forums so they can help where needed, like some responsible companies do!
