Message 1 of 2
BT Cloud on IPad.
Hi,
I decided to try BT CLOUD on my IPad (IOS 11.3.1) after a long break as it never seemed to work properly. It appears not much has changed. If I try to delete a single file BT Cloud crashes. If I select more than one file to delete it appears to not do anything and the app is unresponsive. I have to exit and reopen the app.
Also the thumbnail images take an age to display sometimes only showing when I select the file icon. I’m on infinity with 50mb speed so unlikely to be that.
Any ideas apart from don’t use Bt cloud.
thanks
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Cloud on IPad.
Hi @Addy Sorry that you are experiencing a problem with the BT Cloud service.
Please contact the Cloud helpdesk on 0800 500 3114 and they will be able to assist you further.
John
