Excalibur1974
Message 1 of 5
BT Cloud query
This should be simple but it's driving me crazy.
I have set up BT Cloud folders for my iPhone and iPad.
I have disabled the syncing facility as I know that if I delete photos on my iPhone then it deletes them on BT Cloud also.
However, the files only appear in the 'all files' folder and NOT the iPhone folder.
Is there any way to move the files into the iPhone folder as I want to keep the photos separate?
Indeed, I want to set up another folder for my wife's iPhone.
Tags (1)
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: BT Cloud query
Hi Excalibur1974,
Thanks for posting and welcome.
I don't know the answer to this off the top of my head but I'll find out and post back.  It may be the start of next week before I get the answer but I'll reply on here when I have it Smiley Happy
All the best,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
speedtrip
Expert
Message 3 of 5
Re: BT Cloud query
Can you also ask when the next PC Windows Client will be released ?
Excalibur1974
Message 4 of 5
Re: BT Cloud query
Hi Robbie- did you ever get a chance to follow up on this query? Best Regards
Moderator
Moderator
Message 5 of 5
Re: BT Cloud query
Hi Excalibur1974,
I'm sorry about the delay in getting back to you. Robbie is off today but I've left a message with him to say you've posted about this.
Cheers
Neil
Community ModeratorNeilO
Kudos”Kudos”
