JimD
Message 1 of 4
BT Cloud website
On the front page of the BT Cloud website when I arrange Documents by 'Last Modified' I get files in an order of dates which isn't chronological. (It's sort of chronological but with seemingly random exceptions.  Can be confusing.  (See attachment.)  Can anyone say why?  Is it meant to be like?  I know the system is cryptic at the best of times but this seems to defeat me. Can anyone explain? Any help welcome.Capture.JPG Can anyone explain
3 REPLIES 3
billcubbon
Message 2 of 4
Re: BT Cloud website
Have noticed this as well recently. If you click on 'Last modified' twice, e.g. reverse chronological then back to chronological it lists them correctly.
Seems to be a minor bug when first displaying the page.
JimD
Message 3 of 4
Thanks billcubbon.  Tried it but unfortunately it doesn't work for me.
BT Cloud Expert
BT Cloud Expert
Message 4 of 4
Hi Jim,
Thanks for flagging this, and apologies for the frustration. It looks like a bug which snuck through our most recent website update (it's only affecting a small number of users). We'll get it fixed in our next website update.
Thanks,
Joe
BT Cloud ExpertJoeV
Show your appreciation!
Kudos”
I am a BT Employee and an expert on BT Cloud. I am here volunteering my own time to give advice, on BT Cloud queries. Go here for more info.
