Eck7003
Newbie
Message 1 of 5
BT Cloud
I unable to log into BT Cloud using the app on my phone. I have uninstalled the app and reloaded it. I have wiped my cache memory however I still get the message "Cannot connect to BT Cloud" with a "Retry" button. It won't allow me to go beyond this screen. I am still able to gain access on my computer. Any advice.
Tags (1)
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: BT Cloud
@Eck7003 What type of phone are you using? I believe there is an known issue with Windows phones at the moment.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Eck7003
Newbie
Message 3 of 5
Re: BT Cloud
Hello, yes I have Lumia 640. Thanks for the reply
BT Cloud Expert
BT Cloud Expert
Message 4 of 5
Re: BT Cloud
Hi @Eck7003,
Sorry you've had trouble on Windows Phone. We published an update last night which addresses the issues, so you'll be able to install it now (if you're phone is set to update apps automatically then it may well have already happened).
Once the update is installed, BT Cloud will start working again.
Thanks,
Joe
BT Cloud ExpertJoeV
Kudos”
I am a BT Employee and an expert on BT Cloud. I am here volunteering my own time to give advice, on BT Cloud queries. Go here for more info.
Eck7003
Newbie
Message 5 of 5
Re: BT Cloud
Thank you, download new version and working fine.
