wrbell
Newbie
Message 1 of 3
BT Cloud
I am trying to set up BT Cloud.
When I try to set up on my Android phone there is a connection eoor. I am told to go to MyBT and set BT Cloud up in My extras.
When I go onto the BT website, login, and view extras .. there is no panel for BT Cloud. Only NetProtect, WiFi and SmartTalk app.
Where do I find the BT Cloud set up ??
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Cloud
Hi wrbell and welcome.
If you’re not seeing the Cloud tile on your MyBT then it would point to an account based problem so we’ll need to take a closer look at that for you. So if you’re still having problems with this send over your details and I’ll look into it for you.
Cheers
David
wrbell
Newbie
Message 3 of 3
Re: BT Cloud
Thanks for your reply David,
I spoke to BT on the phone and BT Technical were supposed to be calling me. However, despite 2 promises that they will be calling, they never have!
What details do you need in order to look into this?
William
