Message 1 of 3
BT Cloud
Hi
I'm trying to share a folder using the BT Cloud website and I am receiving the follwoing error each time
"Sorry - There was a problem creatiung a public link for this item. Please try again later"
I have tried various folders and also on different days, all with thesame response.
any ideas?
thanks
2 REPLIES 2
Distinguished Expert
Message 2 of 3
Re: BT Cloud
@DNLYNCH wrote:
Hi
any ideas?
thanks
From memory, in the BT Cloud Web portal, I don't think you can share folders as such. In a similar manner you can't upload folders from the Web Portal.
You have to create a folder specific to the single files you want to share, e.g. add indivual photos, videos:- this is the subtle difference. Then you email a link to the recipient.
If you go to Help > enter search term "BT Cloud File Share" you will see the guidelines.
Message 3 of 3
Re: BT Cloud
Hope you have made progress. The file share utility in BT Cloud is useful - and simple for the recipient to view your files - perhaps much simpler than other file share services!
