Addy
Message 1 of 3
BT FON x 2
Hi,
I've recently opted in to BT WIFI. The hub (v3) has been updated and on the "Choose a network" settings on the IPAD it shows the hub wifi network and also shows two others.
BT WIFI and BTWIFI-WITH-FON. Both show a full strength signal and I don't think it is a neighbours wifi network as the nearest is about 100m away. I can log on to each wifi network.
Are these two seperate BTWIFI networks or just one with two different names.
Ta
Does this mean I have two seperate BT WIFI networks on my hub, giving 3 WIFI networks in total with the main hub one.
Tags (2)
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: BT FON x 2
Hi.
They are coming from your hub - both used to be called BTOpenzone and BTFon - they are basically the same when coming from the homehub - yes there are now technically 3 wifi connections from your hub.
-+-No longer a forum member-+-
Distinguished Guru
Distinguished Guru
Message 3 of 3
Re: BT FON x 2
There have always been two extra SSIDs but, on my hub at least, they don't always both show at the same time or they may have different signal strengths. I assume that separate connections are necessary for non-BT Broadband customers, who can obtain access either by subscription to BT Wi-Fi or by joining the Fon network. A BT BB customer can connect to either.
