Moderator
Moderator
Message 11 of 54
Re: BT Infinity - unable to opt-out (again) from BT Wi-fi
Hi @chrisdw I called earlier and left a brief message. Just to confirm I have updated the records and would ask that you check again if you are showing as opted and post back to let me know.
If you are still not opted out I will then raise a fault to get this fixed for you.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
chrisdw
Message 12 of 54
Hi @JohnC2, sorry I missed your call. Thanks for doing that, I've just checked my HomeHub, it's still showing BT Wifi as active but I'll check again later in case it takes a while to filter down. I still can't log in to the BT Wifi page at https://www.bt.com/wifi/secure/status.do to check on there though.
asif2017
Message 13 of 54
Rebooted the hub and I can confirm that I have been opted-out!
Thank you
Moderator
Moderator
Message 14 of 54
Hi @chrisdw Thanks for checking that for me. Will you reboot the hub and check again for me.
Cheers
John
Kudos”
chrisdw
Message 15 of 54
Hi @JohnC2, have done a full reboot but it's still showing as active (and my Wifi performance is still abysmal!). Is a factory reset worth a try?
It's a bit frustrating really, everything was fine before it was re-enabled!
Moderator
Moderator
Message 16 of 54
Hi @chrisdw Sorry it hasn't worked. I have raised the fault to get this switched off for you and it can take a few days to resolve. I will keep you updated of the progress.
Cheers
John
Kudos”
Dippu
Message 17 of 54
@chrisdw don't do Factory Reset. Doing a Factory Reset will enable the BT Fon, which is the default setting on all hubs.
asif2017
Message 18 of 54
I rebooted the hub - effectively switched it off. Gave it a few mins and restarted.
chrisdw
Message 19 of 54
Hi @JohnC2, thanks very much, hopefully that resolves it. Just checked again and it's still showing as Active on the HH, I'll try another reboot later though. I appreciate your help.
chrisdw
Message 20 of 54
I had to do a couple of factory resets a few months back when BT were trying to diagnose a connection problem (which was entirely down to their exchange), BT Wifi remained disabled afterwards. It's only become enabled since I moved house.
