Irons
Message 1 of 10
BT Netprotect
Hi,
I am wondering if someone could help me ?
On Tuesday i signed up for further 12 months line rental and infinity. But yesterday my computer crashed and i had to do a factoty restall. But when i sign in to my bt account and go down to the extras it says there is an error and my extras aren't available. So now i can't install netprotection again.
I did call BT yesterday and the gentleman said it would all be up and running today.
9 REPLIES 9
Message 2 of 10
Re: BT Netprotect
You should wait and see if it is up and running today, there is still plenty time for it to be fixed. If it's not fixed today post back later.
My advice and that of others on the forum would be not to use BTNetprotect. It can cause problems on some computers and is a resource hog. Do a search of the forum to see the problems. There are far better free antivirus programs available such as Avast Free and AVG Free.
Irons
Message 3 of 10
Re: BT Netprotect
Thanks for the reply.
I have always used Mcafee and never had any problems.
And for the past year I have used the BT net protect.
Just a shame I can't put it back on yet.
I will put one of the free ones you mentioned on for now.
Thanks.
Message 4 of 10
Re: BT Netprotect
If you do get BTNetprotect showing on your MY Extras and decide to install it, remember to fully remove which ever one you have installed meantime first or it will cause a conflict with BTNetprotect.
Irons
Message 5 of 10
Re: BT Netprotect
Hi,
I still can't get any of the extras to load up in my account.
It just says there is a error.
Any ideas whats going on ?
Message 6 of 10
Re: BT Netprotect
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They are a BT UK based team and if they can help they will reply via this thread asking you to contact them via a link. Once you have replied to them by the link, it can at present take up to five working days for them to re-contact you.
Moderator
Moderator
Message 7 of 10
Re: BT Netprotect
Hi Irons,
Thanks for posting and welcome back!
Sorry for the problems you're having viewing your "My Extras" when you sign into your MyBT account.  Send over your details and we'll help sort this out.
Click on my username and under the "about me" section of my profile you'll see the link to get in touch with us.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Irons
Message 8 of 10
Re: BT Netprotect
I have submit a form.
Irons
Message 9 of 10
Re: BT Netprotect
Hi,
All fixed now.
Moderator
Moderator
Message 10 of 10
Re: BT Netprotect
Thanks for letting us know Irons.
Cheers
David
Community ModeratorDaveM
Kudos”
