0hM1ghty1
Message 1 of 3
BT Parental Control Pop-Up
I am suddenly afflicted with the above pop-up on many sites. I cannot get rid of it. Even clicking 'No Thanks' takes me to another tab, and the original page stays with the Pop-up plastered over it!
I cannot use the method suggested elsewhere (My BT/Disable Parental Control) as I have not installed it, and Parental Control control does not appear on MyBT!
Help!
OM1
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Parental Control Pop-Up
Hi OM1,
Thanks for posting. Sorry you're having problems with the pop up message. I can help with this. Drop me an email with the details, including what browser you're using. You'll get the 'contact us' luink in my profile.
Cheers
David
emit118
Message 3 of 3
Hi I can't seem to find where to create a new post etc, hence why I'm replying. I'm having the same problem. A 'Parental Control' pop-up appears, I click 'No Thanks', I'm completely redirected to another BT page, I then click 'Close', the webpage doesn't load anything so I delete on the browser, BT pop-up keeps appearing still 😞 I'm only on shopping websites, nothing dodgy. Please help! 😞
