fraglerocks
Message 1 of 9
BT Parental Control
Hello All
Hope someone can help with a solution to this. I have been having this problem activating parental control on BT for a while. Each time I tried, it comes back "Sorry, we couldn't turn on your BT Parental Controls. Please try again later."
Its getting a bit frustrating now as even Tech support doesnt seem to know how to resolve the problem.
Can you please help?
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: BT Parental Control
Hi @fraglerocks,
It's good to see you back on the Community Smiley Happy
This is something that we can help you with. I've sent you a private message to get things moving for you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
fraglerocks
Message 3 of 9
Hello Daniel,
Thanks I have responded to your PM.
Cheers
Adetola
redls
Message 4 of 9
Apologies for butting in … I would love to know why BT Parental Control doesn't allow you to dismiss it … Rather upsetting being reminded you are not a parent whenever you look through your extras.
Community Manager
Community Manager
Message 5 of 9
Hi @fraglerocks Good speaking with you today 🙂
I will get back in touch as soon as I have an update about your parental controls. Please either text me back or post here if you need to get hold of me in the meantime.
Community ModeratorStephanie
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 6 of 9
Hi @fraglerocks The team has just updated me now, to say this should be sorted for you.
Could you try activating parental controls again, and let me know how you get on? If there's still a problem I'll go back to the team, that's not a problem.
Kudos”
fraglerocks
Message 7 of 9
It is working now. Thank you very much.
Moderator
Moderator
Message 8 of 9
Hi @fraglerocks  thanks for checking and getting back to us. I'll let @StephanieG  know it's working ok now.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Community Manager
Community Manager
Message 9 of 9
Hi @fraglerocks
Excellent, thanks for letting me know!
Please post back if you have any more queries about your account.
Kudos”
