Community Manager
Community Manager
Message 1 of 1
BT Parental Controls - 'How to...' guide
Hey Everyone,
I have found a useful article about BT Parental Controls.  The link below links to a section of BT.com help that will offer you a guide on doing just about anything with BT Parental Controls.  If you use this extra and run into any problems, this link is a helpful resource.
Cheers Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
