jaytelford
Message 1 of 9
BT Parental Controls still not available months later
Hi,
I am unable to turn on the built in BT Parental Controls because they are "unavailable" it has been months since this problem first occurred and the issue of unavailable parental controls still persists.
I have turned on and off my smart hub and also reset it several times over the months since the issue first occurred and the problem still persists.
Attempts to contact BT about the issue have also failed because the call centre advisors do not understand what I am refering to and assume I am.trying to report connection issues - which is not the case - and thus the problem does not get resolved.
1: Can any forum user who has had this problem in the past tell me what worked for them when attempting to fix the issue of unavailable parental controls
2: Can the mods direct my issue to the correct team (the people who deal with the built in network level BT Parental Controls (the ones I should be able to turn on from the within my online account)
I am now getting fed up of this issue persisting. The only reason I joined BT and then renewed my contract was to take advantage of BTs parental controls as they sounded better than what was offered from competitors and for months now, have been unable to use the one feature that persuaded me to join and then stay with BT.
Regards
Jason
Tags (1)
8 REPLIES 8
Dean007
Recognised Expert
Message 2 of 9
Re: BT Parental Controls still not available months later
Hi @jaytelford
I’ve asked a moderator to come have a chat. They can get fairly busy so may take them a while so keep checking back.
In the meantime, can I ask if you have placed any orders with BT or made any other changes to your account?
Moderator
Moderator
Message 3 of 9
Hi @jaytelford Sorry that the parental controls service shows as not available on your profile.
We will be happy to help you get this fixed if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
jaytelford
Message 4 of 9
Thanks I have done that now.
Moderator
Moderator
Message 5 of 9
Hi @jaytelford,
Thank you for sending in your details. I'm sorry you've had problems setting up Parental Controls. I've made a few changes, that should have corrected things. Please can you try the Parental Controls again and let me know how you get on?
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
jaytelford
Message 6 of 9
Hi, thanks for looking into this for me.
The parental controls are now available and turned on but when I try to set a level "light, strict" etc, I get an error that says
"There was an error saving the data"
And then another error message that says
"Sorry we were unable to complete your request, please try again later"
Jason
Moderator
Moderator
Message 7 of 9
Hi @jaytelford,
Thank you for trying that and for posting back. I'm sorry that hasn't worked.
I've deactivated Parental Controls at my end. Can you try setting them up again to see if that resolves the issue?
PaddyB
Kudos”Kudos”
jaytelford
Message 8 of 9
Hi, thanks again for the reply.
I can confirm that I have been able to active the parental controls and set the correct level as well as add some sites to the allowed/blocked lists.
I am now just waiting for the settings to kick in - which the message said would be within 2 hours.
So for now, it seems that parental controls are fixed and working again.
Jason
Moderator
Moderator
Message 9 of 9
Hi @jaytelford,
Thank you for posting back. I'll check back with you tomorrow to make sure it still working okay.
Cheers
PaddyB
Kudos”Kudos”
