Message 11 of 20
Re: NOT AGAIN!
forum moderators advised see if they can assist you
Message 12 of 20
Re: DNS issues and the new update for Home Hub 5
What you have done is exactly what I was going to suggest Smiley Wink
simplysup
Message 13 of 20
Re: BT Parental controls are broken
I'm a Me Too for this problem. It started after I cancelled out of extending my broadband contract (to get BT Sport for free, but I wanted to check what would happen if I moved house).
When I checked the status of Parental Controls in My BT, they were de-activated. In an attempt to resolve the issue I activated Parental Controls, waited a couple of hours, then de-activated - and deleted - them. My BT now once more says "Activate" for the Parental Controls option, which should mean they are not activated on my account. However If I change my DNS back to Google's DNS, which I was using, I still get the error message:
"You're seeing this page because BT Parental Controls is active and you are attempting to connect to a DNS server outside of our network.
You may have selected a different server in your network settings or installed an application that uses an alternative service."
Several restarts of the Hub, and clearing browser caches, has had no effect.
Nigel
UrbanGrunt
Expert
Message 14 of 20
I have also enabled/disabled the parental controls to see if that would fix the issue without any joy.
Any mods around that are able to look into this? I think its something that needs to be addressed and fixed quickly. Using BT's DNS is not a solution for some of us that need to use an alternative dns service
Moderator
Moderator
Message 15 of 20
Re: NOT AGAIN!
Hi PheeragHfre,
Thanks for posting. Sorry your relative is having problems with this. I think john46 is correct in this instance so could you get your relative to log on to their MyBT just to check if parental controls has been switched on?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 16 of 20
Hi Guys,
Thanks all for posting. We're chasing this up with product supprt and will post back if there are any known issues.
Cheers
David
Kudos”Kudos”
PheeragHfre
Recognised Expert
Message 17 of 20
Re: NOT AGAIN!
Snaffuu
The Problem being that this relative is WAITING FOR A Confirmation Email needed to update THIS Accounts BT ID!
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
simplysup
Message 18 of 20
Update: I have just reset my DNS servers back to Google (making no other changes, nor resetting the hub), and I have full web access, no more Parental Control messages.
Perhaps someone did something in the BT back office; here's hoping it's a permanent fix..
Nigel
UrbanGrunt
Expert
Message 19 of 20
Fixed here also, thanks mods for fixing the issue.
Craig_UK
Message 20 of 20
All good here now, Google or Open DNS both work again 🙂
