rdlane
Newbie
Message 1 of 3
BT Smart Hub 2 Manager Icons
In BT Smart Hub 2 Manager, what is the meaning of a number in a blue box in the top left hand corner of a connected device icon
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Smart Hub 2 Manager Icons
@rdlane Thanks for posting, I've asked the Hub team if they can help answer that for you. I'll post back when they update me.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 3 of 3
Hi @rdlane,
The Hub Team have got back to us.
That 6 shows the device has an IPv6 address.
PaddyB
Community ModeratorPaddyB
Kudos”
