derekb
Message 1 of 7
BT Smart Talk caller display error
Thought I just test the caller display when using Smart Talk app on my mobile, connected to wifi.  It should display my mobile number to the callee but it doesn't it displays a totally unrecognised number - 03316 ****** (well unrecognised to me).
Any ideas how to set the correct CLI?
regards
Derek
6 REPLIES 6
Message 2 of 7
Re: BT Smart Talk caller display error
You are seeing the service ID code, which is a dummy number, I have asked a moderator to assist you.
Moderator
Moderator
Message 3 of 7
Hi derekb,
I've removed the telephone number you've posted, it's a non geographic telephone number that you have been allocated for use with the smart talk service.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
derekb
Message 4 of 7
Ok so how do I get the system to display my mobile number as advertised...
Moderator
Moderator
Message 5 of 7
Hi Derekb,
I'll be able to take a look at this for you. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Kudos”
Message 6 of 7
I am having the same error as above - caller id displays as a 0333 etc number. Was using the app with no problems but changed to a new handset and this problem has begun.
ChrispyB
Message 7 of 7
