ChrispyB
Message 1 of 3
BT Smart Talk caller display problem
Like other members I am having caller display issues with Smart Talk in that my Service ID has suddenly started coming up on CLI rather than my mobile number. Nothing has changed except an auto update of the app. Can someone advise me how to get it back to my mobile number please.
Many thanks,
Chris
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Smart Talk caller display problem
Hi ChrispyB,
I'll be able to take a look at this for you. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ChrispyB
Message 3 of 3
Problem solved. I'm not sure what you did to correct it but thanks for your help.
