deakie
Message 1 of 14
BT Smart Talk
Hi Community,
I'm stilll having issues trying to manage my smart talk on the bt website.
Nothing happens when I press active or blocked users.
Is anyone else having this issue?
Very frustrating.
Regards,
Deaks
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: BT Smart Talk
Hi @deakie,
Did you manage to get this fixed? If not, I can take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
deakie
Message 3 of 14
Re: BT Smart Talk
I contacted you through the MOD portal as you said.
Still unable to sort thanks.
dbv333
Message 4 of 14
Re: BT Smart Talk
I'm having the same problem after an Android phone upgrade . I called BT for advice and was told that Smart Talk is no longer supported, yet I see from the BT web site that it is still featuring. Assistance would be much appreciated!
rld
Newbie
Message 5 of 14
Re: BT Smart Talk
BT Smarttalk has been discontinued - someone seems to have forgotten to tell peopleto update the website and pull it from the various app stores as well as actually telling customers!
xmarksthespot
Message 6 of 14
Re: BT Smart Talk
The position, as I understand it, is that BT Smart Talk is not available to new customers. It will be withdrawn ("discontinued") for existing customers in December 2018. I can currently use it without problems, but will miss its ability to help me make calls when outside the EU.
Based on having recently received conflicting and often erroneous information from BT staff regarding the status of BT Smart Talk, it's obvious that communication within BT regarding the future of Bt Smart Talk has been very poor. And as for telling customers, you're spot on. Heaven forbid that a communications company would actually communicate to the very people it relies on!
deakie
Message 7 of 14
Re: BT Smart Talk
Thanks Robbie,
I now have my smart talk up and running again. The delete/reset you did, done the job.
Kudos to you for that.
However, when I go to manage it on the web page, I get this error...
Error 500--Internal Server Error
From RFC 2068 Hypertext Transfer Protocol -- HTTP/1.1: x.x.x.x Internal Server Error
The server encountered an unexpected condition which prevented it from fulfilling the request.
Took out the server IP for security.
Not sure why i'm getting that.
Deaks.
Moderator
Moderator
Message 8 of 14
Re: BT Smart Talk
Hi @deakie
I tried calling you back this afternoon but wasn't able to reach you.
My colleagues have got back to me to let me know things should be sorted out now.  Can you check it when you have a spare minute and let me know please?
I'm not about tomorrow so if I haven't heard from you I will try and give you another shout on Saturday.
Cheers.
Robbie
deakie
Message 9 of 14
Re: BT Smart Talk
Hi Rob,
Ok, I can now access the manage page once again but the same (original) issue remains.
I can see active or blocked users.
Pressing either tab does nothing.
So technically, I cannot manage any user though there are two.
It's all good fun.
However, I must give you kudos for sorting out the smart talk itslef.
That now works again. Brilliant work Robbie. Much appreciated mate.
Regards,
Deaks
Moderator
Moderator
Message 10 of 14
Re: BT Smart Talk
Hi @deakie
Thanks for posting back to let me know that.
I'll get on the case again and you'll hear from me next week.
Cheers,
Robbie
