clique-al
Message 11 of 12
Re: BT TV App Everywhere
Hi @Martin--W
Thanks for getting in touch and noted your comments. Much appreciated.
Can you just clarify, am I right in saying under App (Menu) TV Channels
“Watch BT Channels” this is my subscribed channels but in SD?
When I refer to “Full TV Listings” all channels are showing, but its only
the SD channel numbers that highlighted watch live. If I select a HD channel
number it highlights not watch but record. So is that correct or should be able
to watch if I’m subscribed to HD channels. Await your further feedback. Thks Al
BT TV Expert
BT TV Expert
Message 12 of 12
@clique-al
Yes, you are correct. But this then links in with my previous response regarding the variable bandwidth and the picture displayed will be as good as your connection allows - and of course may change as you watch if you went from wifi to 4g to 3g etc.
Kind regards,
Martin.
BT TV expertMartin
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
