PAno
Message 1 of 7
BT TV Recording License Usage
I like the idea of setting recordings through the BT TV App on my phone but don't want to use one of the device licences. Is there any way around this?
6 REPLIES 6
Message 2 of 7
Re: BT TV Recording License Usage
No. See link about registering devices.
http://bt.custhelp.com/app/answers/detail/a_id/51209
PAno
Message 3 of 7
I do know about device limits but Sky used to have a separate app for managing the box and for streaming so I thought there may be a less obvious way to do it with BT. Is there a suggestion box anywhere?
Message 4 of 7
PAno
Message 5 of 7
Cool. Thank you
Distinguished Guru
Distinguished Guru
Message 6 of 7
Why don't you use the Youview App to set recordings on your phone instead of the BT TV App.  (The Youview app doesn't currently handle channel 434 BT Sports UHD but does all other channels)
PAno
Message 7 of 7
Thanks zulu17. That's just what I was looking for.
