Snowdog37
Message 1 of 4
BT Virus Protect - Deactivating
BT Virus Protect (McAfee) wants to deactivate and supplies some random email and wants a password - I don't remember setting up this email or password. BTID does not work either. I see others on here have had similar problems but there does not seem to be a solution to fix this available for me to use - anyone out there help, please
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT Virus Protect - Deactivating
@Snowdog37 sorry about that, we have raised this with the Virus protect team who are working with McAfee as it appears to be a common fault.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Snowdog37
Message 3 of 4
Yet, more than a month later and all I've been told is that this is a common problem.  So, since BT provide this protection as part of there package, if I suffer any loss as a result of a virus attack, etc -then are BT accepting liability due to there not being a fix for this "common problem"?
Distinguished Guru
Distinguished Guru
Message 4 of 4
McAfee's AV has a long history of poor performance and functional issues, and was even denounced by its founder, John McAfee, a couple of years back. Best advice you'll get here is to give up on it and go for one of the reliable, free products available online (eg Avast or Avira). Personally, I've had no issues during many years with Windows Defender and an occasional scan with Malwarebytes.
If you do decide to dispense with McAfee make sure to use the removal tool.
