roadrunner67
Message 1 of 18
BT Virus Protect.
I have BT Virus Protect, why do I often get a notification informing me I need to renew as it's about to expire. I never have renewed and it doesn't appear to expire.
17 REPLIES 17
roadrunner67
Message 2 of 18
Re: BT Virus Protect.
Waste of time asking a question on here.
stereohaven
Recognised Expert
Message 3 of 18
I ws just about to ask the same question, so it's a shame that someone saying you will never get an answer (which may be true), has been marked as the solution.
If someone at BT/McAfee could learn to spell "Activate" as well that would be nice. It's the small things. Smiley LOL
Useless...Useless...
NeilO
Moderator
Moderator
Message 4 of 18
@stereohaven and @roadrunner67 I'm sorry you keep getting the renew subscription message. Can try following these steps to fix this?
First check that your computer's date and time are correct and that you have the latest virus updates.
Here's how:
  1. Right-click on the time displayed in the bottom corner of your screen
  2. Select Adjust Date/time
  3. Check that the time and date are correct, changing them if they're wrong
  4. Now check that the Timezone is correct. If you're in the UK then it needs to be set to "(UTC) Dublin, Edinburgh, Lisbon, London". It's a good idea to tick any option that offers to automatically adjust to daylight saving time
  5. Click OK to confirm the settings and close the window
  6. Now right-click the McAfee "M" shield icon in the bar next to the clock at the bottom of your screen. Click on Verify subscription
  7. BT Virus Protect will then check your subscription. You should then see a "Verification Complete" message
The "Renew subscription" message should now have been replaced with "Your Computer is Secure". But if it hasn't, then try the following.
  1. Click on the McAfee "M" shield icon again to open BT Virus Protect
  2. This time click on Renew my subscription
  3. BT Virus Protect will renew your subscription and if everything's OK, you'll see "Your Computer is Secure"
If this doesn't work and you're still being asked to renew your subscription, try removing and then reinstalling BT Virus Protect.
roadrunner67
Message 5 of 18
There doesn't seem to be any way of stopping these notifications, I've had six already today telling me my security subscription expires in four days. I'm getting Pi**ed off.
StuartH
Moderator
Moderator
Message 6 of 18
Hi @roadrunner67
Sorry you're still getting these notifications. Can I ask how many devices you have installed Virus Protect on?
Also have you tried uninstalling and reinstalling as per the instructions in this link
Stuart
roadrunner67
Message 7 of 18
Hi Stuart,
I have Virus Protect on a laptop and my desktop.
I have just carried out a reinstall on my desktop to see how that goes, it will be a while before I know if the problem is fixed, I will leave the laptop for now.
Thanks, John.
roadrunner67
Message 8 of 18
That didn't work, I just had another notification informing me that my virus protection ends in four days. I'll just live with it.
DanielS
Moderator
Moderator
Message 9 of 18
Hi @roadrunner67,
If you'd like us to look into it for you please let me know.
DanielS
newagetraveller
Message 10 of 18
I too have had this same problem with BT Virus Protect. It's never worked from day one with BT. Something that is meant to be included should work, why offer it otherwise?
Download, install and it is either not active or needs re-activating. Initially it worked until I received warnings that there were only "x" days left to re-activate then it would not work.
Tried de-activating then re-acivating each device, in my account. Download and install to a particular device - no not active. In my account it advises that I have three licences active - how when it doesn't on  all of the three devices.
Activation takes me to McAfee's log in which can't be done - no detail for that!
I've just had to continue using what I've always used, free anti-virus.
Oh, I did contact BT and that was a total wate of my time, useless. The person hadn't a clue what I was tyring to have rectified. I submitted a complaint about that which, again, was a total waste.
