johnf_01
Message 1 of 2
BT Virus Protect
Hi, can someone help?
I have just downloaded and installed BT Virus Protect.  However, I got an error message on completion which said the anti-virus package had not installed correctly.  I then downloaded and ran McAfee Virtual Technician which detected 3 problems it was able to fix 2 of them.  The third problem was a missing file from the install directory viz. C:\Program Files\Common Files\mcafee\systemcore\mfedisk.inf  The Virtual Technician could not fix this.
Does anybody know how to fix ths or direct me to a patch or the like to install the missing file?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Virus Protect
Hi @johnf_01,
The file sounds like it may have been corrupted when downloading it. Have you been able to uninstall it and try downloading a new copy?
DanielS
