roadrunner67
Message 1 of 2
BT Virus Protect.
I use two BT Virus Protect licences, I want to change one licence from an old laptop and use that licence on a new laptop. I can't seem to find out how to do this.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Virus Protect.
Hi @roadrunner67  welcome back. I've had a look around and you should find the help you need on BT Virus Protect and scroll down to the section "How can I manage my licences?" Post back and let me know how you get on.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
